Rumbling from front suspension
Hi,
If anyone ever hears rumbling from the front suspension at low speeds and breaking, it’s likely the top mounts.
This is a common issue on 2018 onward Berlingos (it also common on the mark 2 Berlingo) as they age but can happen as early as 2 years old.
Not a cheap job as some garages don’t like to do the drivers side as it’s more complicated (more to remove) than the passenger side.
Sorted 80% of the noise with a replacement drop link
£12 for the part and around 25 minutes to swap over
This is very much a DIY job
* jack up car
* remove wheel
* remove old drop link (this is the slowest part as the old bolts need a healthy does of WD40 to loosen)
* install new drop link
* wheel back on
Parts supplier told me they sell slot of droplinks for these Stellantis vehicles, common issue.
I had the drop links changed on my 2020 van a couple of years ago, done under warranty. Symptom was clunking noise when going over bumps etc., though the direction the sound came from wasn't clear - initially I thought I hadn't tied my ladder on the roof rack securely enough.
(01-06-2024, 07:15 AM)ComboLifer Wrote:  Sorted 80% of the noise with a replacement drop link
* jack up car
* remove wheel
* wheel back on
Your parts supplier was correct. I think in my 8 years of B9 Berlingo ownership, the average they seemed to last was 18 months. I tried some very expensive replacements and came to the conclusion they didn't last any longer than the cheap ones, so I just used to buy what was on special offer at the time. As you state at least it's an easy job to do.
It was longer ago now but I don't remember them being such a problem on the M59 model of Berlingo [the model previous to the B9] as I had one of those for six years. Maybe because it was a lighter vehicle?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Well the electric Berlingos (and no doubt the e rifter, e combo life, e Toyota pro ace city) go through drop links every 18 months on average, it’s the biggest warranty claim issue as they weigh a lot more due to the electric batteries.
The issue is back with a vengeance
Now told it’s likely shock absorbers
May as well change top mounts as well
Same issue of rumbling and clonking from suspension while driving was common on the previous B9 model Berlingo from 2008-2018
As they are essentially the same vehicle le but heavily facelifted, nothing has changed in terms of suspension issues ,
2012 B9
61k often at max gross weight , and never less than half that.
Driven in the county that officially has the worst roads in the country.
Currently still on the original links.
Why am I being singled out??
(30-07-2024, 11:09 AM)evdama Wrote:  2012 B9
Same! Currently on 66k without any issues. I did have to replace my top mounts on my Bipper every 20k many years ago though
Not that hard to fathom out if you think about it. You are driving around in in a Berlingo Van 'often at gross weight' That weight is going to be concentrated at the back of the vehicle so the front will have less loading on it, so your front drop links are given a easy ride, I would be checking the rear springs regularly though  Wink
_______________
Not a Citroen  Cry
I've had a pothole smash a front spring....
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
