[Engine] Kjøleviften går ikke oransje trekant kommer opp når motor er varm og går i nødmodus
Jeg er ny her i forumet og trenger hjelp
Har en Berlingo 2012 modellKjøleviften går ikke. Har har byttet formotstand samt temperatur/sensor for kjølevannet
viften går fortsatt ikke.
Hvor ligger sikringen til viftemotor, er det også et rele til denne
Mvh
Halvard Huh
Hei Havard,
sorry but this is an English forum, unlikely that there is anyone here who speaks/understands Norwegian (I think that is the language in which you posted).
2020  1.5 Blue HDi 130 Berlingo XTR
2009  1.5 Diesel Peugeot Partner
2007  1.5 Diesel Berlingo Desire
2003  Petrol Berlingo
Google Oversetter
I am new to the forum and need help
Have a Berlingo 2012 model The cooling fan does not work. Have changed the resistor as well as the temperature/sensor for the cooling water
the fan is still not running.
Where is the fuse for the fan motor, there is also a relay for this
On a right hand drive car [as here in England] the relay for the fan is above the glove box which is on the left hand side, so on a left hand drive car it will probably be in the area underneath the dash above the steering column?
Also take the fan out and check it can spin freely and is not seized which was the problem on my fan
or via Google translate
På en høyrestyrt bil [som her i England] er reléet for viften over hanskerommet som er på venstre side, så på en venstrestyrt bil vil det sannsynligvis være i området under dashbordet over styringen kolonne?[/color]
Ta også viften ut og sjekk at den kan snurre fritt og ikke er beslaglagt som var problemet på viften min
https://alquilercastilloshinchables.info...-berlingo/
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Last Post: ADarkDividedGem
Yesterday 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
Rattling calipers
Last Post: Chrisfox1975
24-05-2026 10:47 AM
