[Brakes] Can you clamp the rubber brake hose?
I need to take off the front calipers, and I was hoping I can clamp the rubber hose that goes from the caliper to the metal line.   Can these hoses be clamped or are they metal braided?
2008 B9 1.6 HDI 90 BHP Model.  120k
I’ve clamped the standard factory rubber pipes using the small screw type hose clamps. It doesn’t take much pressure to stop fluid flow.
(02-05-2024, 06:06 AM)Teep Wrote:  I’ve clamped the standard factory rubber pipes using the small screw type hose clamps. It doesn’t take much pressure to stop fluid flow.
Perfect.  Thanks
Wedge the brake pedal down an inch with something , this will stops any fluid flow.
Yes but be gentle
Rubber tubes have a small diameter ( 3 mm ) nylon tube moulded inside the outer.
They are robust but be gentle !
One thing after another
Yesterday 09:01 PM
12-11-2026 10:41 AM
» Replies: 16
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
