Windscreen wipers banging
Hi
Our windscreen wipers work but every now and then they bang into the end of the windscreen on the drivers side as they sweep.  This can last for a few sweeps or for longer but then another time they'll work normally with no banging into the edge.
The motor seems OK as it's happily swinging the wipers back and forth.
It's not a major problem just very annoying if it rains for any length of time when travelling.
Does any one have the same problem?  Any idea why it happens and/or how to stop it?
(04-05-2024, 07:15 AM)vampirequeen1 Wrote:  Hi
You could just try moving the wiper up slightly on the spline, it might have been put back in the incorrect position in the past after removal.
Mark the position of the wiper in the 'off position' by putting a piece of masking tape each side of the wiper blade. Undo the nut holding the wiper blade on and slightly reposition it a little higher on the spline than the original marked position and then refit the nut and try when it next rains to see if it is still hitting?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
As what multispacer said but don't alter it too much !! because you might have same problem hitting bottom of windscreen!! (Scuttle )
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
Yesterday 03:36 PM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
