04-05-2024, 05:48 PM
(This post was last modified: 04-05-2024, 05:51 PM by lukestewart85.)
Bought the vehicle cheap as it wasn't starting. Has had new battery, glow plugs and glow plug relay but still no joy.
Code reader read P1349 that wouldn't clear. Changed rhe fuel sender unit in rhe tank and still no joy.
I then found a 70a bubble fuse that had blown on the top of the battery, which I have replaced and cleared the code, but still wouldn't start!
Fuel seems to be getting through to the pump and at rhe injectors, I've now checked to see if there is power at the fuel solenoid on the high pressure pump and it seems to be vibrating and I've measured around 9v. I have split the cable and run an additional earth to negative a now im getting 12v and can hear the solenoid click in but now its throwing another error code up!
This code is now P0003 which won't clear unless I remove the additional ground cable.
I have primed the fuel several times and used a full tin of easy start but still nothing.
I'm really at a loss now and can't think what the problem could be. If anyone could shed any light on this I'd really appreciate it.
