  • 13 Vote(s) - 3.31 Average
[Transmission] Stiff when selecting gears
As title really, went to test drive a 2003 CITROEN BERLINGO FIRST TD X 75, 1560CC DIESEL, MANUAL, VAN. When trying to select gears it was really stiff trying to select gears. There was no abnormal noises and could be driven, but its not right.
Has anybody had this problem before and know what i should be looking at to get it sorted?
(29-04-2012, 09:57 AM)qucifer666 Wrote:  As title really, went to test drive a 2003 CITROEN BERLINGO FIRST TD X 75, 1560CC DIESEL, MANUAL, VAN. When trying to select gears it was really stiff trying to select gears. There was no abnormal noises and could be driven, but its not right.
How many kilometers it had done ?
Mine is MK2, 2007 with the original clutch and 270,000 Kilo
and has no problem like this, maybe it is the Gear.
i was thinking maybe it's something with the gear linkages. its got 103000 miles on the clock
(29-04-2012, 07:45 PM)qucifer666 Wrote:  i was thinking maybe it's something with the gear linkages. its got 103000 miles on the clock
ן am sorry, No Idea,
Check it with your mechanic
I think Husqyman posted a thread might be helpful. Try search for "stiff change"
It could be worn linkage, that's the first thing that I would check for.
Could be a seized up or rusty linkage, some penetrating oil followed by a good dollop of copperslip around the linkages. I had a similar fault on my old Pug 306 which has the same set up.
had the same problem get yourself some gear box oil it worked a treat
Have you a lot of play at the gear lever?
If so change both the front short linkages, costs about 30 euro. And give where it drops from the lever a squeeze to take out freeplay.
I always change the gearbox oil when I get a new car or van because chances are its.never been done before
Today 02:32 PM
Berlingo 2026
Last Post: xtimex
Today 05:06 AM
Yesterday 12:15 AM
Yesterday 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
