Amdro Dometic Origo stove can it be changed to gas ?
Hello, thank you for the amazing forum (I will donate once I sort out problem with Paypal).
Just bought a second hand Amdro boot jump and v excited about using it Smile
I was wondering, as the seller was saying the alcohol Dometic Origo stove it comes with doesn't heat v well, if these stoves can be converted to use gas instead, or if you can buy a second gas stove the same size to fit the Amdro ?
Thanks and good wishes
James Smile
I would stick with the meths stove if you plan on having the doors closed (and i wouldn't do that either)
The Gas stove would give off CO2 and you will be likely to gas yourself if you plan on using it to heat.
A small diesel heater might be a better solution or even better a Wallas Diesel Stove with the flip down lid option so it can be converted into a heater?
Does your kitchen/ stove pull out? so no chance of using it with the doors closed. The spirit stoves sell for a lot of money second-hand and can not be swapped to gas so try to find a gas stove that fits into the same space as the origo. Maybe Amdro sell them.
Berlingo undertray
Today 06:24 PM
» Replies: 15
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
