Heavy steering
After some advice...my steering became heavy couple of days ago, did the usual checks, power steering fluid levels and tyre pressures, both fine. Checked good old Google and you tube and followed the turning wheels lock to lock several times incase any air in system, I thought I'd cracked it as drove it to work straight after and was lovely back to normal, but then driving home few hours later back to the heavy steering again. Tried again today, fluid level doesn't go down at all during process and no signs of leaks, so no topping up needed, no nasty noises coming from pump, or steering.  Steering was lovely and light again after 15 lock to lock repetitions. Left sitting for 3hrs, now back to heavy steering, the fluid does look pretty dark. Really hoping it's nothing serious/expensive...what do you think? It's a Berlingo Multispace 1.6hdi '57 plate.
I 've heard that the UJ at the bottom of the steering column can stiffen up and cause the steering to appear stiff ,
Worth a shot of wd40 type stuff?
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Thank you. Will definitely give that a try tomorrow
Not certain but I think your power steering pump is likely to be the culprit, when ours went there was no loss of fluid
Peter
[-] The following 1 user says Thank You to Romahomepete for this post:
  • TLawrence
Wire through bulkhead
Last Post: Jakejjt
Today 05:25 PM
Loose tailgate spoiler
Today 04:52 PM
Engine Fan Running
04-12-2025 11:07 AM
Last Post: SonofaGun
02-12-2025 10:51 PM
02-12-2025 06:14 PM
Rear view mirror
02-12-2025 08:19 AM
Gear number display
Last Post: MarcoLingo
29-11-2025 09:02 AM
25-11-2025 04:20 PM
Lapik's 5-th Berlingo
25-11-2025 08:21 AM
ë
24-11-2025 09:08 PM
