Thoughts on Leisure battery powering radio when car is in "economy mode"
Hi All,
I've got a 2017 Berlingo Multispace (Feel edition, I think).
I'm thinking of adding a leisure battery under the passenger seat and charging it via a Dc-Dc battery charger because I'm told that a voltage sensitive relay won't work with my alternator... I'm looking at the Renogy DCC1212-20 if anyone has any thoughts on this.
However, the real question is, Can I back feed power into the radio when the car goes into "economy mode" and everything shuts down so I can continue to listen to the radio when parked up or am I opening a can of worms I might not be able to close again?
Thanks in advance
Al
Which genius came up with that "economy mode"? At least with my M59,
Making you have to restart the engine every ten minutes or so, so that you can listen to the radio.
A French Fail.
If it was called "Anti silly sod mode" and it cut the radio & lights after say an hour, it would be A Gallic Great Idea.
227,00 miles,  (Resurrected at 186,000)
Smile
Not impossible to do it, but make sure its fused well. Thinking of doing it myself. As smutts its a daft idea, but for those that leave it on all night, its great! But minority over rules the majority, or as  smutts said, Making you have to restart the engine every ten minutes or so, so that you can listen to the radio.
A French Fail. Wink Wink
Your Reach is further than your Grasp
(14-05-2024, 05:19 PM)AlRamsay Wrote:  Hi All,
I’d assume stock radio gets the economy state from canbus and thus would not play even if it is powered elsewhere. Not sure about this though.
With aftermarket stereo you definitely can feed direct +12V trigger. I have done this with a toggle switch: either stock switching wire or from fuse holder with constant battery voltage.
Newbie
Last Post: Vmkst
Yesterday 08:48 PM
MyBerlingo App Service History
Last Post: Requiem
13-02-2026 10:43 AM
Mk 3 K9 blower not working
12-02-2026 04:57 PM
Diagbox 9.91 free download
Last Post: Slowmo
11-02-2026 06:29 PM
Last Post: Slowmo
11-02-2026 06:26 PM
» Replies: 29
07-02-2026 05:42 PM
heater down
05-02-2026 04:49 PM
Rear seat belt breakage
02-02-2026 02:34 PM
High mileage vehicles ?
Last Post: chrisl
01-02-2026 09:22 PM
Berlingo rear suspension
Last Post: Geordie graham
01-02-2026 01:13 PM
