Identify a part
Hi all
Can you help me with a problem, please.
The part (ringed in black in the attached image) is making a sort of whistling / buzzing noise when I turn the Ignition on?
If it has anything to do with it, I had the cam belt / water pump changed a couple of weeks ago
Can you tell me what it is, and why might it be making this noise?
It would certainly help if I knew what it did, Help please!
Life is so tiresome
Attached Files Thumbnail(s)
It is the what was called throttle valve on gasoline engines. Essentially a flapper shut off valve just before intake manifold.
It whines on my car as well. I consider it normal.
Strut Top Mounts
Today 07:58 PM
Yesterday 09:30 PM
Yesterday 09:27 PM
Rear seat belt breakage
Yesterday 04:13 PM
removing front strut
13-09-2026 06:10 PM
12-09-2026 05:49 AM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
29-08-2026 08:39 PM
