Threads: 4
Thanks Given: 3
Hello, my Berlingo starts fine apart from after a long-ish trip when the engines hot and has been running for a while.
There is no crank, just a click coming from the engine.
Jump pack doesn't seem to work but push starting it does.
I haven't done much yet to source the problem apart from charging the battery to full.
Have seen a few similar threads so sorry if this is a common question, have seen it could be a number of things so just wondering if knowing it only starts with a push start and not a jump pack narrows it down/eliminates certain culprits?
Wanna have a crack at sourcing/fixing the problem before sending it off to a garage so any thoughts towards it would be appreciated.
Threads: 41
Thanks Received: 408 in 365 posts
Thanks Given: 134
31
Starter motor or starter solenoid which sits on top of the starter motor. Possibly affected by the heat from the engine when warm?
Could also be electrical connections to the motor or to earth. Check the heavy duty cable that goes from battery to the solenoid on top of the motor for good connections.
As you are getting a click when trying to start it does point to motor or solenoid , you could try tapping the motor when someone holds the key in start position. If you can get near the motor to do it that is , as some motors are hidden deep into the engine bay.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 6
Thanks Received: 2 in 2 posts
Thanks Given: 8
Sounds like starter solnoid, mine did it a few months ago exact same symptoms and I put up with it for a week or two flicking the key several times till it caught but eventually wouldn't play ball and I ripped a muscle in my leg trying to push it down the street to bump start it. New starter £30 off fleabay seller called carpartsinmotion has sorted it. As said one bolt is a bit awkward to get at but doable if you pull the battery and airbox to maximise access. One thing I had to do was replace the ring connector on the switch wire to a spade type as new motor has spade connection.
The following 1 user says Thank You to racey83 for this post:1 user says Thank You to racey83 for this post
• marzzden
Threads: 4
Thanks Given: 3
Cheers everyone, starter motor seems to be the fault as predicted. Getting a new one on Thursday so hopefully that will resolve the issue. If not I'll keep in mind the on/off trick!
