Hello Thinking of Getting a 5 seat Berlingo
Wink
Help Please ,,,,,,,,,
Thinking of Getting  a 5 seat  Berlingo  , Because  i do not want to go  big on 7 seats ,But need to Have hoist fitted and power wheelchair in fit in boot space with the  3 seats up !
As  My Disabled wife  don,t want to be straped in her chair in back ,
    So models ---- 2015  - 16-17-18 -19  20  Models     What ones is Best
  Would  like Manual
/ petrol or diesel
 /   and  do they all ad blue ??      if anyone has a 5 seat one anychance of mesurement in inchs   front to back/ side to side   of boot with seats up please ----
            thanks all in advance   im in uk by the way !! Smile  Or   Would The Same  size peugeot horizon be better ???
   I Hear the  berlingo xtr is good one ?
(21-05-2024, 03:49 PM)graceland Wrote:  Help  Please ,,,,,,,,,
  Would  like Manual
/ petrol or diesel
Lots of questions in there but there are things you need to consider before any purchase. I see you want to be able to put in your wife's wheelchair in the rear and have a hoist fitted.
The modern diesel engines fitted [not only in Citroens and Peugeots] but all vehicles after about 2010 all have DPFs [Diesel Particulate Filters] fitted and those after 2016 also have AdBlue to reduce emissions and comply with the various standards introduced around the World, plus Citroen/Peugeot also had an intermediate system [Eolys] fitted between about 2012-2017 as well as the AdBlue. While these all reduce emissions they also add a lot more complexity to the engines with a plethora of extra sensors monitors everything so there is a lot more to go wrong and modern diesels can quickly turn into a nightmare of faults if you only use the vehicle for short journeys. If you plan to do a good number of longer journeys and some motorway journeys, then yes a diesel would make sense but otherwise steer clear of them. modern diesels with DPFs will clog up fast and cause all sorts of problems if just used for short journeys all the time. If you are going to only being doing short journeys then look for a petrol model, the problem being there are very few compared to the diesels around.
You are right in wanting to go for a manual. The 'Auto' box in the Berlingo isn't a real auto at all, it's a sort of semi-auto and they are problematic.
The Berlingo XTR model is a higher spec model and amongst other things has the advantage of three separate rear seats [rather than a split 60/40 bench on the lower spec models] which means you can remove, one, two or all three rear seats to give you more space.
I have a very early Berlingo Multispace XTR [2008] but the dimensions are the same up to 2018. So for the boot are with the three rear seats in place, the dimensions are:
Width 47"
Depth 36"
Height 43"
The Peugeot equivalent of the Berlingo is the Peugeot Partner and it is mechanically identical to the Berlingo.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • graceland
  Would  like Manual
/ petrol or diesel
Width 47"
Depth 36"
Height 43"
THANK YOU LOADS  ... It is  mainly   short trips     a 17  mile trip most  weeks   and  general around town    But 2 or 3 Trips from Glos to Yorkshire   each yr ..    But sound like boot space is good .. Thank u
Quote:Lots of questions in there but there are things you need to consider before any purchase. I see you want to be able to put in your wife's wheelchair in the rear and have a hoist fitted.
The modern diesel engines fitted [not only in Citroens and Peugeots] but all vehicles after about 2010 all have DPFs [Diesel Particulate Filters] fitted and those after 2016 also have AdBlue to reduce emissions and comply with the various standards introduced around the World, plus Citroen/Peugeot also had an intermediate system [Eolys] fitted between about 2012-2017 as well as the AdBlue. While these all reduce emissions they also add a lot more complexity to the engines with a plethora of extra sensors monitors everything so there is a lot more to go wrong and modern diesels can quickly turn into a nightmare of faults if you only use the vehicle for short journeys. If you plan to do a good number of longer journeys and some motorway journeys, then yes a diesel would make sense but otherwise steer clear of them. modern diesels with DPFs will clog up fast and cause all sorts of problems if just used for short journeys all the time. If you are going to only being doing short journeys then look for a petrol model, the problem being there are very few compared to the diesels around. By the way, if you're interested in something exciting while considering your options, check out some sports betting websites like betandreas-ozbekiston . They offer great deals and insights, adding some fun to your decision-making process!
I have a 2016 Berlingo 5 seater and it is perfect for carrying a wheelchair. And the XTR also comes with some extra features like roof rails and skid plates.
[-] The following 1 user says Thank You to fxgfcgf@ASS4 for this post:
  • graceland
  Would  like Manual
/ petrol or diesel
Hi graceland
Do you want a hoist?  I have one removed from a 2016 Berlingo.
Do bear in mind that if you're just storing a chair in the back (as opposed to a person on a chair), you may not need anything more than a shortish folding ramp, eg, https://www.theramppeople.co.uk/wheelcha...lti-option
Hoist is a bit too specialist for me to comment on.
[-] The following 1 user says Thank You to shtu for this post:
  • graceland
  Would  like Manual
/ petrol or diesel
Hi graceland
Attached Files Thumbnail(s)
Hi   Again thank you   for all the info all ,,,  Heart
Just one more thing  how long is a  7 seat one conpared to the five seat ????  Rolleyes
 in feet if poss ????  please  Shy
The Hoist thing  will be second on list  then chair !!! Confused
One thing after another
Yesterday 09:01 PM
12-11-2026 10:41 AM
» Replies: 16
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
