Citroen Berlingo 2004 Radio won‘t work
Hello Guys,
I‘ve just bought a 04 Berlingo. Unfortunately the Radio doesn‘t work at all. Seems like somebody added aswell a hands-free device.
Even when I pluged out the handa-free device and put the radio straight in it didn‘t work.
Could eventually anybody help?  Big Grin
Thaanks
Attached Files Thumbnail(s)
(21-05-2024, 09:13 PM)Aleks95 Wrote:  Hello Guys,
I‘ve just bought a 04 Berlingo. Unfortunately the Radio doesn‘t work at all. Seems like somebody added as well a hands-free device.
Even when I plugged out the hands-free device and put the radio straight in it didn‘t work.
I think you may have posted this in the incorrect model sub-forum. If your model is from 2004, then it would be an M59 model.
We need a bit more info than in your post, is the radio the original Citroen fit unit or an after market unit?
Does the multi-function display on top of the centre console work?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Ou I‘m sorry for that!
It‘s an original radio, and yes the console on top works perfectly!
(22-05-2024, 07:14 PM)Aleks95 Wrote:  Ou I‘m sorry for that!
Not a problem, it's just if you post in the correct sub-forum [M59] in your case, you are likely to get more replies.
As the display is working correctly, it is unlikely to be a fuse, as the fuse does both the radio and the display console.
I would think, as you say someone has added an aftermarket hands-free device in the wiring, they have altered the wiring in some way and caused a problem. You will probably need to check wiring with a meter to see in you have 12V coming into the radio on the supply line.
Fuse box/Wiring diagrams for you model are on this thread: https://www.berlingoforum.com/thread-17165.html
_______________
Not a Citroen  Cry
Last Post: stu76
Today 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
