Cladding rear pillars?
Total newbie here so be gentle on me. Ive spent an hour on search already and didnt find answer
I've stuck insulation on my  side,rear door  and roof panels and covered them  with fluffy stuff. Think I'll have to have a go at sticking carpet too as its very bitty as is.
Saw a video of carpet directly app,ied  onto bare rear pillars and you could see every hole and indentation and it didn't look so great. I've a LWB so the pillars are quite big and are full of holes.
Do i need to cover them with something before carpet?
If so.what?
Do I need to ply ceiling before carpeting ?
Does anyone know of a guide or video on how to make the rear window storage boxes. Thanks.
(21-05-2024, 11:07 PM)Divechick Wrote:  Total newbie here so be gentle on me. I've spent an hour on search already and didn't find answer
I've stuck insulation on my  side, rear door  and roof panels and covered them  with fluffy stuff. Think I'll have to have a go at sticking carpet too as its very bitty as is.
Saw a video of carpet directly applied  onto bare rear pillars and you could see every hole and indentation and it didn't look so great. I've a LWB so the pillars are quite big and are full of holes.
Do I need to cover them with something before carpet?
If so, what?
Hello, you probably need to supply some more information to get some replies?
What are you planning to use your conversion for and how often? [I'm asking because of you plan to use it a lot, you probably want something a bit more hard wearing than a bit of carpet, that could get grubby very quickly with a lot of use]
What is your budget?
With regard to rear window storage boxes, what model/year of Berlingo do you have as the rear windows are different shapes/sizes depending on the model?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
If so, what?
Thanks a million for reply. I have a LWB Berlingo HDI. Cargo Van. Twin sliding doors + rear asymmetric barn doors. Three seats up front and a frame behind drivers seat.
The rear side window panels I've insulated above the plastic cover over wheel arch. Id love to get rid of these but there are wires sitting on the arch. Not sure theres much room now for boxes. Looking at videos with them.. They seem to be on the car version with huge window sill to rest them on.
Apart from regular getting around vehicle..i sleep in the back when away at weekends but would like option of staying in it for a week or two or maybe longer ( looking at forced retirement soon)  and going abroad doing running races.
Thought carpet rather than tongue and groove as that seems even more difficult and heavy. Are there other alternatives for lining a van?
I used contact carpet clue in a can to stick foam insulation to the roof of a van  It worked quite well and stopped condensation dripping on me overnight.
This is a link to a similar thing I used. Did not stick carpet over it as I thought it would be too heavy.
https://i.ebayimg.com/images/g/n7cAAOSwB...-l960.webp
Could use carpet on the rear pillars using the same kind of glue
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(23-05-2024, 12:29 PM)brodfather11 Wrote:  I used contact carpet clue in a can to stick foam insulation to the roof of a van  It worked quite well and stopped condensation dripping on me overnight.
I have insulation stuck on roof already. Did you leave yours uncovered? Thanks
Last Post: gitt
Yesterday 08:27 PM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
2011 B9 DPF warning light
22-01-2025 10:51 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
21-01-2025 09:18 AM
» Replies: 23
Free To Collect From CO14 8LD B9/K9 Floor Mats
21-01-2025 12:43 AM
