25-05-2024, 01:03 PM
Well, where do I start.
My Citroen dealer, is not Citroen, it's a franchise from Citroen, in fact I can't find an actual Citroen garage in the UK (perhaps someone knows differently).
What does the service consist of?
It depends where you look.
- Haynes and other manuals: give a list of things to be changed and things to be done.
- My dealer just says: annual service plus.
- Citoroen says: Systematic Operations.
I contacted Citroen Customer Care to ask what Systematic Operations means:
Change Oil filter
Change Cylinder housing plug seal
Check all liquids and top-up or change if necessary
Check security/tightness/operation of various components
So I ased if the oil shoould be changed.
They said only if the dealer thinks so.
After a lot of discussion, Citroen say that the changing of any fluids is down to the dealer, as they can test them to see if they need changing (Really ?), and that Citroen don't stipulate what should, or shouldn't be changed.
Basically, Citroen don't control, or stipulate the maintenance, it's your local dealer that is responsible for everything, except when you ask them if the xyz needs changing in the price of the service, when it's a, "no, Citroen say that's an extra"
I've paid in advance for 2 normal, and 1 major service when I bought the car. If there's no such thing as different services, I wonder what I will get for the major one.
Completely fed up with this "buck passing", and "no responsibility taken" attitude. I'm assuming it's because they don't believe in their products.
Change Oil filter
