Replacement van door check strap(?)
How much would it be/how easy to replace the check strap on the rear door for a Berlingo enterprise? Mine has twice now, stopped reconnecting and is just floppy. This time between 2 of us, we can't get it to connect again. I'm certain that it needs replacing.
Attached Files Thumbnail(s)
Mine occasionally won't work and I need the doors wide open because my idiot neighbours park too close.
Might be worth a fiddle before forking out on parts
Clean up up all mating surfaces of rust and gunge with a tiny wire brush then flush with wd40 and treat with sewing machine oil.
Work the catch back and forth a few hundred times until it is FULLY opening.(Imho this is the culprit as it only needs to be a tiny bit stiff to fail.)
Pull the strap right out with both hands until it clicks
in the outmost position-it can be reluctant.
Once you get it to connect then release and reconnect a further hundred times and it's good for another winter
Thanks Ev, I'll give that a go. I wasn't looking extortionate new parts, but considered a trip to the scrappy. This sounds simple enough and will give it a go. I've definitely got WD-40, but it's the silicone spray rather than oil. I take it that's a no go?
I can't get my comment to edit, but the catch itself moves very easily, it's just the strap that's acting odd.
(29-05-2024, 05:31 PM)LukeC Wrote:  I can't get my comment to edit, but the catch itself moves very easily, it's just the strap that's acting odd.
WD40/gt85 is fine,it's but not as long lasting.
You have to grasp and pull on the strap with all your might to get it to click on the out position-normally the door would act as a lever to do this.
  • LukeC
Can I use the silicone spray, or would it have to be oil?
Issue resolved, thanks to the lovely evdama! A very knowledgeable individual!
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
