Ad Blue - How much do I need?
Hello,
I have a Citroen Berlingo blue HDi Van 1.5 diesel and it says it is '1700 mls before no start.'
Does anyone know how many litres of Ad Blue I would need to top it up? I don't really want to have it spilling out of the top since I don't know what damage, if any, over filling would do. Not sure the paint work on my van would appreciate it either.
Thanks in advance
Mike.
Berlingo Blue HDI van, 1.5 diesel, 75 ( Dec 16, 2019)
I always just put a 10 litre containers worth in.
2020  1.5 Blue HDi 130 Berlingo XTR
2009  1.5 Diesel Peugeot Partner
2007  1.5 Diesel Berlingo Desire
2003  Petrol Berlingo
I just fill up from the pump at the garage - usually works out cheaper
There have been instances where the tanks function is compromised by the adblue crystalising because it's not used up fast enough.
At work we only fill our Sprinters half full so it will slosh around,after several 18 litre tanks had to be replaced.
It's seems to have stopped the problem
It's unlikely to cause damage to paint if it's not left on the too long
(05-06-2024, 02:24 PM)evdama Wrote:  There have been instances where the tanks function is compromised by the adblue crystalising because it's not used up fast enough.
Thanks Evdama
You should wait until warning light comes on then top up with at least 10litres. That was how my Cit garage told me to do it. Current model 22 reg uses around 10litres every 5k miles which is double what my previous 17 reg used. I was also told that tank is 17litres & light comes on with 3litres left.
  • clapgun
Brake problems again!
Yesterday 08:47 PM
CITROEN VIRTUAL SERVICE MANUAL ALL MODELS
18-06-2025 05:34 PM
» Replies: 33
P0691 P0693 cooling fan circuit problem
18-06-2025 07:32 AM
Does My Van Have A Tracker ?
Last Post: Mark604
17-06-2025 03:01 PM
Last Post: Cumbrian
15-06-2025 09:02 PM
14-06-2025 10:57 AM
» Replies: 36
Last Post: Vlad
12-06-2025 02:36 PM
11-06-2025 10:29 PM
Limp mode, no other symptoms.
Last Post: KiwiMurfy
11-06-2025 10:33 AM
Nearside Headlamp bulb change
10-06-2025 01:59 PM
