Threads: 10
Thanks Given: 5
Hello guys, just bought a 62 plate van and have been desperately trying to find the specs for this model, but to no avail. I believe that it's a 625Kg 1.6 HDi (75ps) L1 Enterprise.
I am trying to ascertain what type of oil it takes, (viscosity, synth or semi, etc) and what micron value the fuel filter employs? I also have no handbook or user manual, so if there's a link to all the vehicle specifications, I would be very grateful.
Many thanks.
Threads: 27
Thanks Received: 19 in 18 posts
Thanks Given: 4
12
I've got an 18 plate 625 enterprise 1.6 hdi, and all the records of oil changes show 0W30. I got it second hand, but at least the previous owners gave the service history to me.
The following 1 user says Thank You to LukeC for this post:1 user says Thank You to LukeC for this post
• axxeman
Threads: 27
Thanks Given: 4
12
the bottles I have had state that it's fully synthetic. I apologise that my reply may be late, and of no further use to you. If you're in doubt, you should be able to ask advice from a garage who will be able to look on their magic systems and tell you for free.
Threads: 39
Thanks Given: 1
4
An 18 plate could have the 1.5 engine which does indeed have 0-30 or even 0-20'
We have a 2007 with a 1.6 engine and that uses 5-30
It is my understanding that all modern oils are synthetic unless it states otherwise. My classic land rover still uses 20-50 mineral oil
Peter
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
10-06-2024, 07:05 AM
(This post was last modified: 10-06-2024, 07:43 AM by evdama.)
I have a 625kg 1.6 hdi 75 enterprise van 2012
The motor is a DV6ETED
![[Image: IMG-20240610-083131-4.avif]](https://i.postimg.cc/y6mqm5Vn/IMG-20240610-083131-4.avif)
It is happy on 5w30 or 0w 30 according to the latest PSA spec. but it must be low sap Citroen
/Pug variant and full synthetic
Air filter is 1444tv, oil filter is 1109ay.
The oem manufacturer is Mahl
Both are very easy to change.
If you have the luck of the devil and/or specialist tools the fuel filter change will be straightforward
If not, it will be hours of entertainment.
(9809721080)
• axxeman
Thanks Received: 66 in 61 posts
Thanks Given: 2
10
You don't need to fuss about that - buy a part that fits from a decent brand, eg, I bought a Bosch one for about £20. Mahle was mentioned, Mann, Hengst, Febi, there's umpteen out there.
I don't recall the fuel filter being especially difficult or needing special tools, apart from the usual terrible access which goes for everything under the bonnet.
Threads: 81
Thanks Given: 165
20
10-06-2024, 03:12 PM
(This post was last modified: 10-06-2024, 03:13 PM by evdama.)
You will get whatever micron the filter manufacturer sees fit ,so as shtu says just get a reputable brand.
The primer button on the fuel filter housing sometimes 'doesn't' leaving you to use a priming pump or just cranking the engine over with no fuel in an injector system that relies on the presence of fuel for its own self preservation
You never know-you might get lucky.
