  • 11 Vote(s) - 3.36 Average
[Engine] Replacement ECU PIN
Hi All, an update from my previous thread ...
As mentioed earlier...
"2002 Berlingo 2.0HDi M49 Siemens SID801 is going into limp home mode, limiting revs to ~3000rpm and not much power. This is intermittent though, I could start up and drive a few yards or a few miles. Key off leave it a minute or so and MIL goes off when started and you pull away.
I was getting a few air bubbles in the fuel lines so replaced fuel filter (which was black, no shiny fillings in filter housing though) After filter change no bubbles once system was bled through.
Chatted to the AA guy at the Local Halfords and he scanned for DTCs and found
P1113 P1114 P1164 P1198 most pointing to Fuel Pressure Sensor.
So replaced that with 2nd hand one from PCR in Worthing.
All was well for few miles then MIL popped up again....Doh.
Disconnected battery overnight to reset ECU...No scan tool to clear codes.
Reconnected battery this morning and now it won't start or even try to. Fuel is getting to the common rail as on cranking it squirts from the High Pressure (HP) lines if you crack them off slightly. Fuel cut-off switch is depressed as am I.
Any thoughts from anyone out there? Fuel tank is over half full.
Does anyone in the Brighton area have a Lexia diagnostic set by any chance."
Well since this I have purchased a Lexia 3 from Easydiagnostics... A very helpfull guy.
Plugged in and have found car has been fitted with a replacement Engine ECU, with 197000 miles on it's chip! scanned VIN did not tie up with log book VIN.
Checked the MOT history on line with DVLA and all appears OK wrt the vehicle mileage of 122808 so it's not been clocked.
I have 2 faults in the BSI -
1 Permanent Fault Evaporator Sensor !! I don't have A/C so what's that about
2 Permanent Fault Engine ECU reception. Could be reason ECU is locked out.
So I'm thinking at the moment that in disconnecting the battery overnight the ECU may have reset to it's old PIN and is now not talking to the BSI.
So now I'm in the position of I having the PIN for the Vehicle VIN but not for the replacement ECU VIN.
Is anyone out there able to provide PIN if I give you the VIN. I know this is a big ask but worth a try.
PS if anyone in Sussex needs a Lexia...
Bear with me on this I'm trying to update this thread with a pic which I'm not sure you can but here it goes anyway...
Thanks to those replying with where to get PIN. Buit things get even stranger in Bingo land!
I was on Lexia till late with Jim (Lexia seller in Scotland who was viewing Lexia over the internet via Teamview - Now how trick is that!!).
What he noticed was that in the BSI ID area there is a Field called
"Additional Number" which just has 0000000000.
Image should be here..
[Image: 2qwo4sg.jpg]
Anyone got any clues on the Additional Number..Long shot i know.
Attached Files Thumbnail(s)
(30-04-2012, 02:14 PM)Bertilingo Wrote:  Hi All, an update from my previous thread ...
I'd be interested in the answer to this as have same problem.
no clue on the additional number but your kilometer reading (its french, all ecus remember mileage in kms) does tie up with your mileage, divide by 8 and times by 5 Wink
as for the security code, citroen will get it yu for 24 quid plus vat from memory, as far as i know third parties cant get it unless thru citroen? never tried tho TBH.....
does bsi vin match the vehicles chassis??
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
