Anyone replaced input shaft bearing?
Hi All,
Got a 2011 Berlingo van, 1.6HDI 90hp (no DPF or DMF), with a BE4 gearbox.
I somehow stuffed up a clutch change last year and about 2k miles in a grinding/scraping/rattling sound started developing when the clutch is up, most prevalent when in neutral but also in gear when there is little road noise i.e. coasting at 10-20 mph in 1st or second. When the clutch is fully pressed the grinding stops. I don't think its the clutch release bearing as the pedal has to be almost to the floor (totally disengaged) for the noise to stop and you can almost hear the "momentum" to whatever is grinding slowing down. I've checked the box has more oil that it needs according to the level plug on the side.
I assume its the input shaft bearing has eaten itself... has anyone changed this before i.e. does it require a total gearbox disassembly or can I pull the old one out (need a press?) from the bell housing side without having to actually get inside the gearbox?
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
