Oil filter replacement K9 2021 1.5 diesel
Where is it in the engine bay and is it easy to replace from above?
Also what is the correct engine
oil specification given I don't know if it has the later camshaft?
2021 Berlingo Flair M (K9) 130D
I.T. is there to help, but unforgiving if you make a mistake
The oil filter is quite high up, behind the air intake. You have to take off the air intake pipe to access the oil filter housing. It's a bit tight spacewise but otherwise fairly straightforward. The tightening torque is quite precise (25.5 Nm on my vehicle) and there's not much room to manoeuvre, so I bought a short-handled torque wrench specifically for this job (though the last time I changed the filter, just as the wrench was telling me to stop tightening, I could feel a sudden increase in resistance anyway).
I think a 2021 model would need the new 5W30 RCP oil, but I'd check with a dealer to be certain.
[-] The following 1 user says Thank You to notsofast for this post:
  • uk_friendly_fire
2019-2022 DVR5Rxx up to OPR 16885 you should use 5w30 PSA B71 2290
Other models use 0w20 PSA B71 2010
Cars and repairs have many how to on youtube
https://www.youtube.com/watch?v=utIQ8WlAbD8
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
