Split seat to normal seat fixings any ideas
Does anybody have a natty ideas for fixing a captive nut into the square hole . Trying to fit a normal seat where a split seat is. All the fixings are there but one of the holes has no captive nut in it and access from underneath is hampered by the trunking covers things which cover that area.
Attached Files Thumbnail(s)
I initially thought about a plate with the correct sized threaded hole over the sqare hole.
But the plate would also then have to be attached somehow
  • OMG
Only thing I can think of is weld a small plate over the square with a captive nut attached in the middle. Didn’t really want to get into welding if possible. Hoping somebody might come up with a good idea.??
What about a rivet nut. It may do what you need .
https://www.amazon.co.uk/eSynic-Rivet-Nu...099&sr=8-5
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • OMG
Trouble is the hole is 14mm square and designed for the captive nuts that are in the rest of the holes so to big for one of those. No clever answer me thinks. Will have to investigate the channel running underneath. Not sure what it’s for?
Rivnut would be the bodgy solution, but they're quite soft metal, into a square hole, holding the seat base - it just sounds like a recipe for disaster.
[-] The following 1 user says Thank You to shtu for this post:
  • OMG
Is this front seat or rear seat, cannot identify from the picture?
If front, you might be looking for part 3 at attached picture. It can be accessed by lifting the front carpet. Parts no. is 7214R5.
[-] The following 1 user says Thank You to Drummond for this post:
  • OMG
It’s the front passenger seat. After looking at the channel underneath don’t think the captive nut is underneath this . The floor in the cab is another skin over the underside of the van. No access to be able to put in a captive nut from underneath. Best I have found are these which are strong and can be fitted into a blind hole.
https://www.fastco.co.uk/lindapter-hollo...LEQAvD_BwE
lift the carpet
the bolts era secured by a plastic support that can be removed and moved to where you need
[-] The following 1 user says Thank You to jocas74 for this post:
  • OMG
Did not take the carpet up. Taking carpet up reveals how to move captive nuts? Assumed they were fitted from the back on vehicle assembly and couldn’t be moved.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
