Ply thickness for narrow bed
I'm making a single bed 80 cms wide. It will be reinforced along the length with 2x4" planks ( fitted underneath so the bed rests on the 2" side)
I've bought  and cut 9mm ply but now concerned i should have got the 12mm. Would i get away with this thickness given it's quite narrow?
(18-06-2024, 11:25 AM)Divechick Wrote:  I'm making a single bed 80 cms wide. It will be reinforced along the length with 2x4" planks ( fitted underneath so the bed rests on the 2" side)
You should be okay, mine was 9mm with lots of cut-outs to lighten it,  but where the hips shoulder went as above strengthen it, 14st my weight so not light, but it did only bend the wood, wish I had kept it, as a boot jump firm made it.
Your Reach is further than your Grasp
[-] The following 1 user says Thank You to jtr rhyl for this post:
  • Divechick
I checked it, just a minute ago and mine is 2 plates of triplex wood. I measured 9 mm thick, moving n top of each other to make the bed broader (80 cm). My weight is 65 kg, and to be honest I think it can handle 100+ kg, who knows much more?
I would choose for 9 mm plywood
Attached Files Thumbnail(s)
(25-06-2024, 02:54 PM)EM58 Wrote:  I checked it, just a minute ago and mine is 2 plates of triplex wood. I measured 9 mm thick, moving n top of each other to make the bed broader (80 cm). My weight is 65 kg, and to be honest I think it can handle 100+ kg, who knows much more?
I stood on it and it bent more than i expected. I guess with mattress on top of would be fine but to be sure i got another  sheet of 12mm and got someone to cut it down for me. I'll use the 9mm for furniture or maybe a drawer.
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
