[Warning Light] U0140 after upgrade to second hand radio
Hello
After i upgraded to second hand radio i get fault U0140 Lost Communication With Body Control Module, and  also a yellow check engine came on and stays on .
I read somewhere that the fault code is pretty normal when upgrading to another headunit that is not official, maybe someone knows about this.
But i have no idea if  fault U0140 would activate the yellow engine symbol, maybe some of you would know this, or the faultcode and yellow engine symbolis two different causes?
Everything in the car seems to be working as before
The Teyes radio i bought  send uses a canbus descrambler to get information from the canbus and comes with a OBD 2 canbus reader .
Regards
[Image: check-engine-light-icon-1616189100.jpg?c...size=980:*]
(19-06-2024, 07:41 AM)mikeh79 Wrote:  Hello
Regards
While I cannot help with your specific problem with your fault code. One thing that I thought I should point out from your post is that the Berlingo M59 model does not use CANBUS but uses a simpler/earlier version called VANBUS which maybe is not compatible with your new radio?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Ahh sorry this thread should have been posted in tje b9 section
Yesterday 05:21 PM
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
