Threads: 10
Thanks Given: 5
22-06-2024, 10:06 AM
(This post was last modified: 22-06-2024, 10:06 AM by axxeman.)
Hello again forumites. Having cleaned the rear of my 62 plate B9, I wanted to be able to remove the black trim side panels that sit over the rear wheel arches but am somewhat reluctant to just "grab and jerk". I did buy a trim removal kit with all its little plastic bits and bobs but still don't know where to begin and the only YT video seems to be a different model so not exactly relevant.
So, I need someone that knows how to do this without creating unnecessary damage please?
Thanks.
Threads: 81
Thanks Received: 395 in 338 posts
Thanks Given: 165
20
23-06-2024, 06:34 AM
(This post was last modified: 23-06-2024, 09:44 AM by evdama.)
I plylined my then-new 2010 b9
If I can remember correctly the panels are fairly indestructible and will pull off ( reluctantly) but you may have to replace one or two of the little white plastic captive clips which are "disposable"
I'm sure I still have the panels lurking at the back of a shed somewhere s If there's time today I might make an expedition to see If they exist.
• axxeman
