Fault code F40A and the fix
Here's a new one.
Scanning the van for faults the other day (I need to remove the egr blank I installed while getting to the bottom of the injector faults), The BSI came up with an unusual error that wouldn't clear,
    F40A
    Oil Gauge Fault
    From - Local
    Characteristation of the fault - Not Characterised.
Delving into the live data for the BSI with the engine running, everything looked OK apart from,
    Measured oil level - Value invalid.
This fault would make you think that the issue is the level\temperature sensor at the back of the block, and it may well be.
But not always. In my case, the fault was shown because when the engine was started, the oil was warm.
Leave it until it was cold, start up, and the so-called "fault" has cleared by itself.
Top work Citroen. Rolleyes
same fault code here. it just dissapeared randomly out of nowhere...thanks i give it a try
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
