Leak after replacing diesel filter
Have a leak after replacing the diesel filter from the down hose
Attached Files Thumbnail(s)
Some filters have " screws " on the top of them - bleed / drain screws I believe - maybe one on these is slack ? maybe one of your push on fittings isn't seated fully ?
Presume it is a 1.6 Hdi from the photo ?
A 1.6 filter can be lifted out of its housing to gain access to " looking " at the pipe connections even with the pipes still connected, maybe you could lift the filter and take a look ?
Unlikely that the filter itself has a leak through the body as it is a moulded item.
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
