I have a 2001 Berlingo 1.4i petrol van, and could do with some help identifying a part. A tube comes out of the inlet manifold, and runs into a component at the back of the battery box. Can anyone tell me what that part is, and what it's supposed to be doing? I attach a couple of photos, showing he tube, and the component it runs into. Thanks.
If you marked it with a line or something on the photo things will be a lot clearer .
I'd use the fullscreen snip app at the bottom right on w10 taskbar
2020 Rifter 1.5 allure
2010 B9 red XTR w a v. 2001 1.9d DW8B white Berlingo 2005 2.l green Berlingo 2001 1.9d DW8B white Berlingo berlingo 1.4 red multispace 1993 xud 1.9 red partner
(27-06-2024, 06:19 PM)brodfather11 Wrote: Its not clear (to me anyway) what tube you mean .
Sorry. I've highlighted the tube I mean in blue. It's the same tube in both photos, running from the manifold, into the component.
The component looks like it's part of the Citroen build. But could it be part of the AC LPG conversion that's been fitted? There was a T connector joining the same tube to a brass nozzle at the bottom of the LPG pump.
Can anyone help me with this ? If I remove the LPG installation, to where, or to what should I connect the tube coming out of the inlet manifold ? It's circled in yellow. Thanks.
03-08-2024, 10:21 PM (This post was last modified: 03-08-2024, 10:23 PM by joskin.)
(29-07-2024, 08:41 AM)Gadgetman Wrote: There should be a line going to the Brake servo, but I think that one is attached further down the inlet manifold?
Yes, there's nothing going from the sagem inlet manifold fitting to the brake servo. I've got it running fine now, and it runs to the LPG MAP sensor. The problem turned out to be a faulty injector. (petrol injector)
