Wanted Drip moulding seal x 2
Hi can anyone help?
I’m after 2 x drip moulding seals ( the rubber  that runs along inside roofline  and down a post) for 2003 Berlingo multispace HDi forte as failing rubbers have caused a water leak to develop
Went to main dealer none in stock, not surprised as old vehicle but helpful parts guy tried central stock locator to be told no longer available
Anyone have any available for sale
 00009023NN (right hand side)
00009023NL (left hand side )
Thanks in advance , elvet Williams 07771-658255
Are you definitely sure it's those seals that are causing a leak into your vehicle? The reason I ask is that forum members have reported similar issues in the past with leaks into the vehicle, only to find it wasn't either of these seals but something like the scuttle drains blocked causing water to enter the inside of the vehicle.
If you are certain these are the problem [and I find it strange that they both would have failed] then your on line searches might get more 'hits' if you drop the leading four zeros in your part numbers.
so search for 9023NN and 9023NL
PSA group part numbers are normally listed as four numbers/two letters
A quick Google search threw up at least one instance of a 9023NL [albeit located in Poland] but a price of 70 Zloty is about £14 so even with postage, it probably wouldn't be that much more.
https://archiwum.allegro.pl/oferta/partn...13208.html
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Yesterday 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
