Hi all,
I have a fluid leak which pools in on top of the gearbox casing around the transmission selector?
Thought fluid was gear box oil but the colour is more like brake fluid?
Any ideas where this fluid is comming from?
(02-05-2012, 10:14 AM)p63500s Wrote: hi al,l any ideas?
what age , type, petrol or diesel ?
cratch:
I have a 96 partner and the gearbox breather is on the top of the gearbox near the linkages. It is like a round plastic button that turns easily and is loose, between the reversing light switch and the gear linkage /clutch shaft
let us know
02-05-2012, 05:51 PM (This post was last modified: 02-05-2012, 05:59 PM by p63500s.)
Hi there, the lingo its a 99 reg 1.9d five speed, I have had a look again and taken a photo cant see a the plastic button thing?
oh, photo is upside down.
regards nick
this a better photo from the front of the engine/passenger side. You can see the oil/fluid reflections in the photo, is the breather one of these nuts in the pic?
The breather is the top hat looking nut at the bottom right of your last picture so it's not coming from there.
Looking at your change lever and the mark on the cable just above it I would say it's dripping from above. cratch:
02-05-2012, 07:14 PM (This post was last modified: 02-05-2012, 07:22 PM by brodfather11.)
(02-05-2012, 05:51 PM)p63500s Wrote: Hi there, the lingo its a 99 reg 1.9d five speed, I have had a look again and taken a photo cant see a the plastic button thing?
regards nick
Looking at mine the vacumn pump for the brakes is just above that puddle. (Your big white thing in the photo foreground??? )My one has a small leak from the seal where the pump mounts on the cylinder head, Has yours got a big leak? cratch:
regards nick
just reread your original post , it may be brake fluid being pumped out, It is possible for the brake fluid to leak into the servo unit from the master cylinder and possibly being sucked into the vacumn pump then expelled onto the g/box cover, Is your brake fluid level ok?
02-05-2012, 07:29 PM (This post was last modified: 02-05-2012, 07:35 PM by p63500s.)
Hi, that mark on the cable was done by me when i diped a rag in there to see what colour the oil/fluid was.
hi brodfather11, i will check the brake fluid level, thanks for the advice. The colour of the fluid is of a more brake fluid in colour then the redish gearbox oil, so you might be on to something here.
