Front Brake Pads
            Hi all, I'm currently replacing the front discs (304mm) and pads on my 2021 Berlingo van. I have sourced the discs (Brembo) but I can't find the pads anywhere. I have tried various different websites using my vehicles registration number but none of the suggested pads are the same as the ones already fitted. Does anyone know where I can source them (see pics). Thanks.
(29-06-2024, 02:50 PM)Speckled Jim Wrote:  Hi all, I'm currently replacing the front discs (304mm) and pads on my 2021 Berlingo van. I have sourced the discs (Brembo) but I can't find the pads anywhere. I have tried various different websites using my vehicles registration number but none of the suggested pads are the same as the ones already fitted. Does anyone know where I can source them (see pics). Thanks.
Have a look at this Ebay page: https://shorturl.at/uw3BL
Not suggesting you buy these or from this company [although I have actually used them in the past for my Berlingo spares] but the reason I included the link it gives the PSA group number on your pads [9839379280] in the OEM number list and lists a number of alternatives including another PSA group number: 1647880280
It also lists the numbers on that advert as being for 304mm discs.
So might be worth searching under that number and seeing what you find? If you can find one locally with that OEM number then take your old pads to compare?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • Speckled Jim
Thanks for replying, they seem to be the correct pads, I was not the first owner of the vehicle and it looks like the calipers may have been changed at some time. None of the pads recommended by parts websites show these as an option. Thanks again.
In the case of odd brake pads, you can draw around the old pads and take your drawing or old brake pads to a local motor factor,. If they are any good they will soon find you replacement pads by comparing them to your drawing or old pads.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
This sould be the correct pads for the K9 brake disk 304mm
orignial parts number : 16 369 254 80
Attached Files Thumbnail(s)
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
