  • 15 Vote(s) - 4.27 Average
1.9d timing belt
Star
just bought a 55 plate 1.9d on 63k
no idea when or if belts has been done so want to do it.
is there a guide anywhere or at least info on what to line up before removal
thanks
When in trouble ,
Or in doubt ,
Always change your cam belt out ! :whistle:
Good thinking Dek , catchy jingle hey Confusedcratch:
I just got the Haynes BoL from Hlafords. Seems to have reasonably comprehensive instructions. Of course being Haynes there is probably a simpler way.
Malc
Stupid computer!
I've got a 53 plate dw8 1.9d engine on 43k and im doing it in the next couple of weeks as I hear they go early on these models... one question tho - is the waterpump connected to it and do I need to change that belt at the same time?
Whilst the bits are disassembled , best time to do it :thumbsup:
Hi all new boy to this site.
best to put a cam belt kit in with the idler pullies - belt and braces is water pump too - i have seen water pumps and idler pullies break up soon after doing the timing belt if not replaced.
hope this helps
  • ron
Ill fit pump and pulleys as well. I really just need to know where the timing marks are and what to align. I have no probs pulling it to bits. Just need the engine in the correct position before i do
im not sure if there is a manual available for the vehicle but there should be for that engine.
check amazon or ebay for a manual
(03-05-2012, 08:42 PM)polar Wrote:  im not sure if there is a manual available for the vehicle but there should be for that engine.
I refer the honorable gentleman to my earlier post Big Grin
Malc
Stupid computer!
sorry malc Confusedillyme:
that sorts it then buy the manual:thumbsup:
One thing after another
Yesterday 09:01 PM
12-11-2026 10:41 AM
» Replies: 16
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
