berlingo 1.5 hdi problem
hello guys
im bought berlingo 2021y 1,5hdi with 60.000 km but i have the problem, big problem Big Grin
its connected to diagnostic but not have fault code, its zero
DPF its ok, EGR also, dont smoke
the symptoms ar
 increase consumption
its very slow under 2000 rpm (all gear), gas in the floor but he struggles, after that its better,
simple as a turbo to be late, dont know.
someone have experience???????
Did you take it to a garage for diagnosing?
What did the garage recommend?
Lack of power under 2,000 revs could be a few different things.
Software, turbos, pipes, air loss, etc
(04-07-2024, 04:53 AM)ComboLifer Wrote:  Did you take it to a garage for diagnosing?
Tnx for answer
next week im goin to garage
But im also noticed that when the car its cold, have that simptom.
When im turn it off, and start again, when it is on
Working temperature its workin normally. Have power.
Is it a sensor, or vacuum, its mystery???
Someone have idea what to look.?
Hello guys
Today im was on highway and max speed its 140 to 145 km/h fck disaster.
Garage told no fault car its 100%correct
Its possible to someone try to put map, but not so well.
My question is it possible to return to factory settings
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
