P0087
I have p0087 faulty after few weeks after replacing fuel filter.have a fuel leak under the car not from filter housing.its look like an over flow hose or something..i trying to understand if not prime the new filter well can cause it.car run well but only when starter ignite its take a second more
Is this your car filter ???
https://www.catcar.info/citroen/?lang=en...I9PQ%3D%3D
If it was me I'd remove the filter, clean all all the connectors, check the fuel bleed / water drain valve is tight and see what happens.
P0087 is for low fuel pressure, your leak will likely be your cause.
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
