  • 1 Vote(s) - 2 Average
A thank you + EOLYS fluid replacement experience
Firstly, a big thanks to all who post on this forum.  I have lurked on here since being an owner of a 2013 Multispace  XTR and have found it invaluable in keeping small annoyances in check with all the help suggested in the forum.
Now to my own experience of replacing the Eolys DPF fluid...
I removed the offside rear wheel and jacked up the car as safe as it would go (ramps and wood chocks added under structurally sound points as a safety catch all).  This left a large enough gap in the wheel arch to access the connector at the rear of the Eolys tank with my left hand.   There is not much room for sausage fingers between any existing brake lines in the immediate area, and so I could only get access to one of the two release buttons on the connector.  No cigar! It would not release.
So I tried to access the opposite button with my right hand from the underside of the car,  whilst depressing the one that I could reach with my left hand.   There was not enough room to get access with my right hand so.....   I bent a short, flat head  screwdriver approx 45 degrees down the shaft and used that instead of my right hand.  This could get inbetween the tank case and the depressible button opposite the one that I could reach.  When I levered up against the tank casing gently, the buttons depressed and off came the tubing easily.
This gave simple access to attach the filling tube that came with my kit:
https://www.neobrothers.co.uk/car-parts/...fluid-tank
Filling was straight forward and I used two full litre bottles with no overflow coming from the discharge tube.
Reconnected the tank loop hose and all was done.   About 30 minutes, but now I know how to get the connector off it would be less than half that time.   Well within the scope of a DIY'er.
Now to find a reasonably priced Diagbox equipped garage local to Penzance to reset the errors.
Thanks again.
[-] The following 1 user says Thank You to Slavedave for this post:
  • evdama
(04-07-2024, 08:02 PM)Slavedave Wrote:  Firstly, a big thanks to all who post on this forum.  I have lurked on here since being an owner of a 2013 Multispace  XTR and have found it invaluable in keeping small annoyances in check with all the help suggested in the forum.
Thanks again.
Might be worth looking on the 'other' forum [French car] as they have a list of members with diagbox/lexia and a quick look at the list lists someone in Helston, so it might be worth dropping them a message to see if they can help you out with a reset?
https://www.frenchcarforum.co.uk/forum/v...hp?t=56452
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • Slavedave
Having had the pointer to the "other" forum - it appears that he hasn't posted on there for a couple of years.  I have registered with them and am awaiting confirmation.
In the meantime, I visited the local Citroen dealer and asked them to just update the refill parameters.   They said that I would have to have a full diagnostic screen which would cost.....£120 + VAT.   One more thing to potentially disillusion me about main dealers.  I know they have to invest in the software etc, but the videos I have watched on youtube (O'Reilly et al) indicate that it is a matter of seconds to do the reset.
With this cost in mind I am seriously considering investing in Diagbox and an OBD reader now (if the connection on the "other" forum doesn't come through for me).  Am I being too ambitious?   I am pretty competent with computers and software and have a couple of old laptops to hand that I could probably install and old version of Windows XP onto to use for the diagnostic hardware/ software.
Thanks again for pointers.
My Berlingo Multispaces
Yesterday 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
Last Post: Desdinova
27-05-2026 10:15 AM
Last Post: Stevie3393
25-05-2026 12:34 PM
24-05-2026 12:57 PM
