Threads: 9
Thanks Received: 1 in 1 posts
Thanks Given: 2
I’d like to remove the plastics around the rear view mirror for a project, any ideas on how to do this?
Many thanks
2022 LWB 1.2 petrol auto combo life (AKA Berlingo K9)
Threads: 18
Thanks Received: 8 in 7 posts
It will be opa push on construction, so I’m assuming you will need to pry it off but might break one of the holding clips
Threads: 9
Thanks Given: 2
You are spot on, attack the middle with something screwdriver like and it pops into two pieces, then slides apart
I’ve mounted an CarPlay screen up there, will do a fresh thread on that
Thankyou
Threads: 4
Thanks Received: 11 in 9 posts
Thanks Given: 1
If you are not sure how to dismantle any interior trim look for the part on ebay. There are usually photos of the back of the component so you can work out which way to pull or push - such as the attached. Careful removing the mirror cover there are quite a lot of electronics behind it.
Thumbnail(s)
Threads: 9
Thanks Given: 2
Thankyou
Please see
Fitted screen link
For finished project
