Heater blower
Hey lads the blower just stopped on the way home from work this evening.  It doesn’t work on any setting. The last time it gave trouble it only worked on the highest setting so I replaced the resistor pack above the throttle pedal and that sorted it. Now it’s totally gone so what should I check? Is the fuse for it inside the cabin or under the bonnet? That’s all I know to check. Any help appreciated ??
(12-07-2024, 01:02 PM)Lively Wrote:  Hey lads the blower just stopped on the way home from work this evening.  It doesn’t work on any setting. The last time it gave trouble it only worked on the highest setting so I replaced the resistor pack above the throttle pedal and that sorted it. Now it’s totally gone so what should I check? Is the fuse for it inside the cabin or under the bonnet? That’s all I know to check. Any help appreciated ??
The blower motor is in the drivers footwell and has a plug on it that connects to the motor. You could check that for voltage when the blower is turned on.
If it’s the motor then they’re cheap enough to replace, just make sure you get the correct one
Thanks lad
(13-07-2024, 10:28 PM)Lively Wrote:  Thanks lad
Another item that can cause the blower to fail on all settings is the control relay. As you're in Australia you are also right hand drive the relay is up above and behind the glove-box on the passenger side [you need to release some of the lining behind the glove-box. The relay is a plug in type and easy to change.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
[-] The following 1 user says Thank You to Multispacer for this post:
  • Lively
Came on yesterday again. Wouldn’t come on this morning and worked again this evening f**k sake
I must check that tomorrow. I found a part number for a denso one on a YouTube video but when I searched it it is for vans without air con. Anyone here can find me a part number for it or is there any good website ye use to find car part numbers for yere cars?
I must check that tomorrow. I found a part number for a denso one on a YouTube video but when I searched it it is for vans without air con. Anyone here can find me a part number for it or is there any good website ye use to find car part numbers for your cars?
For part numbers, have a look at the catcar info site, if you put in your VIN on the site it takes you to a part catalogue for your vehicle:
https://www.catcar.info/citroen/?lang=en
_______________
Not a Citroen  Cry
  • Lively
Today 11:40 AM
Last Post: JPCoetzee
Today 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
