Threads: 27
Thanks Received: 19 in 18 posts
Thanks Given: 4
12
Hello and welcome!
I would think that you've got a B9 being a 14 plate. I haven't got any pictures to hand, and too lazy to look for some at the moment. You will definitely learn a lot about them from various people here. All the little quirks and regular issues. But also, a lot of advice.
The following 1 user says Thank You to LukeC for this post:1 user says Thank You to LukeC for this post
• Plas33
Threads: 23
Thanks Given: 50
29
29-07-2024, 08:58 PM
(This post was last modified: 29-07-2024, 09:03 PM by Jed Clampit.
Edit Reason: more to say
Hello Plas33 welcome along to the Berlingo forum , first thing i think charge the battery then put a battery tester on the battery if it's okay , then about once a month put the battery on charge it will serve you well , they use some power even when parked up .
A old timer named Ron told me that and it worked , i still do it today.
Ron are you still out there ?
Threads: 67
Thanks Given: 237
50
" Ron " ..... last active on Forum 20-11-2021, 02:24 PM .....
Ron if you still out there .... hope you are " OK "
Serieal Berlingo owner
