I asked for help on how to open the rear view mirror cover so I could add an additional display screen up here
We are out and about a lot  so I wanted the ability to have a different map from the main one on the built in display (I have two phones)
I purchased a cheap android out / CarPlay screen from eBay for £44
Tool the mirror cover apart, used cut up cable ties through drilled holes then refitted
It’s great to have extra mapping / Google services
Comes on and off with ignition and auto connects wirelessly
Attached Files Thumbnail(s)
2022 LWB 1.2 petrol auto combo life (AKA Berlingo K9)
[-] The following 1 user says Thank You to Daddypig for this post:
  • boop
It looks like it’s obscured the mirror which it is a tiny bit but the pics make it look worse due to angle
Hope it helps someone
(20-07-2024, 07:48 AM)Daddypig Wrote:  It looks like it’s obscured the mirror which it is a tiny bit but the pics make it look worse due to angle
Some of these wifi screens come with a front and rear view camera so you could probably stick one rear pointing camera to your rear window and have a constant feed of DVR images fed into it and view the rear in split screen.
ex: 2003 1.4i cargo
Yeah I was looking at those, as I get older I try to keep things I do as simple as possible.
If I was to do this again I think I’d try a rear view mirrored shaped screen that runs android / CarPlay and mount it just above like I did
A video feed for the mirror is fine until it starts playing up
I’ve been running Gaia maps on it, very interesting, i discovered that there is a source of a river very close to my house
I mounted my rear view camera monitor in the same location. It may be a coincidence but I've noticed that my rear view mirror no longer auto-dims at night. The sensor is at the top of the mirror and I wondered if my camera monitor is obstructing the sensor making it inoperative. I notice that your display also partially obscures the sensor; is your rear view mirror still auto-dimming?
I’ve not noticed, but I’ve never really noticed the auto dimming, now I’m trying to recall if I’ve driven it in dark enough conditions since fitting
Will report back
(20-07-2024, 07:42 AM)Daddypig Wrote:  I asked for help on how to open the rear view mirror cover so I could add an additional display screen up here
I would like to do this but what is the satnav that you used please?
Make life easier - go automatic. Cool
These are displays that connect wirelessly to your mobile phone via Apple Carplay or Android Auto.
This is similar to the one I have, https://www.hotukdeals.com/deals/podofo-...nd-4755119
Yesterday 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
04-09-2026 05:28 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
23-08-2026 06:25 AM
