[Engine] Is it the end for my engine...?
Hi
I have a 2004 Partner 2.0 hdi Siemens.
Lately, it's been burning oil like crazy... heavyyyy white smoke under moderate acceleration (see photos). Changed the turbo because the old one broke. Runs smoother but still blows white smoke like crazy and has a lot of Blow by (from oil cap and dip stick)
Is this the end? Could it be something salvageable?
Thanks for any feedback
Attached Files Thumbnail(s)
White smoke is coolant burning ,black smoke is oil in my experience. Head gasket gone? Coolant need topping up regularly ? Any white residue, water in the oil? If that is the problem and the head is alright replace the head gasket and it might live again!
(25-07-2024, 02:38 PM)OMG Wrote:  White smoke is coolant burning ,black smoke is oil in my experience. Head gasket gone? Coolant need topping up regularly ? Any white residue, water in the oil? If that is the problem and the head is alright replace the head gasket and it might live again!
Hi
Thanks for your reply!
No, not at all! Doesn't need topping up and Doesn't loose any coolant, nor white residue, no water in oil or any of the symptoms.
The smoke is grey/blueish and smells like burnt oil. The only thing that needs topping up is oil
When you say you have blowby, that is the tell tale sign of worn piston rings.
Blue Smoke is oil burning
White smoke is typically seen on start up as this is atomized diesel due to low combustion temperatures
Black smoke is over fueling, usually down to bad injectors or pump.
Sounds like oil smoke. Wonder if it ate a piece of the last turbo when it let go? If so could be damage to pistons, rings or both. Did it smoke before the last turbo failed? Either way probs be cheaper to replace the engine or whole car, definitely easier. Just another thought, is the replacement turbo unit new, recon or second hand? Could be the turbo at fault??
Compression test the engine to discount rings but unfortunately there isn't much more that could pressurise the crankcase to that extent. Is it down on power/lumpy idle?
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4  208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
Today 03:36 PM
Last Post: JPCoetzee
Today 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
