25-07-2024, 06:26 AM
Hi all,
Having a problem with my 2007 Berlingo M59 1.4L KFW (TU3JP Engine).
Since I purchased the car, I was seeing coolant blowing out the coolant expansion tank cap once the car got up to temp after driving around for a bit.
It would just blow out excess coolant, but ALOT of coolant multiple times as it kinda "cycled" through cooling - I assume this is thermostat opening and closing.
Found a small hole in the thermostat housing, so replaced thermostat housing, thermostat (with a Mahle 89degree unit).
Completed full system flush with additive, buttoned everything up and all looked good.
until it blew coolant again....and again...and again.
Looked like a head gasket. So order a Coolant Exhaust gas test kit (the blue liquid that sits in the thing above the coolant tank and you suck the air in from the coolant take to determine whether it had exhaust gases present).
Tested twice over a 20min period. While the car was warming up, and when it was completely warmed up and both top and bottom rad hoses were hot.
Both times passed. no exhaust gases present.
As a Hail Mary, replace coolant tank cap. Fixed. All was great. driving around for a few weeks with no issues, holding coolant well and maintaining temp perfectly.
First long trip: after 100km the car temp start to creep up, heater was blowing cold air (at max heat) and reached 95degree's, so pulled up to see what was wrong.
It blew an average amount of coolant out, but still had plenty in the tank. everything else looked ok.
Got back on the road after 10mins and the temp went back to normal - high 70's to mid 80's, heater was blowing heat (not an amazing amount of heat, but was definitely heating) and completed another 350km with the car staying at 78 > 85 degree's depending on speed (lots of little towns to go through when you go form 100km/h to 50km/h)
Pulled up for a couple of nights and then the trip back.
It was pretty good for a while, then starts to become hotter travelling at 110km/h 93>94>95>96. Checked the heater. Cold air again.
Pulled up. See what's what. Nothing. No coolant blowout etc. Sit for a couple of minutes. Start back up, hit the road and the temp drops back down to normal running temps.
Then over the course of next 3/400km it did this a couple of times. Sometimes there would still be heat coming through the vents and the temp would be rising on a pretty flat road, no traffic, 14degrees C outside.
Got it home without overheating it, and now trying to work out what it is?
Head Gasket?
Water Pump?
Radiator?
Blockage? Or something still in the system after the flush that's blocking things up randomly?
Heat Exchanger in cabin - but this would cause the engine to increase in temp right?
Got a very large trip coming up in a few months. 500 to 800km per day. rough roads, will be getting hotter by then, so keen to get this sorted early so I know its solid.
Cheers,
Johno
Head Gasket?
Water Pump?
Radiator?
Cheers,
Johno
