30-07-2024, 12:38 PM
(This post was last modified: 30-07-2024, 12:39 PM by Merelass.)
I have a disability Berlingo, and I needed to fully refuel for a long journey, so I filled it with diesel until the pump went click. When I went into pay, the attendant pointed out that fuel was coming out from the rear of the car, and it was quite a lot. So much the garage did not want me to drive off and covered the fuel with sand. After ten minutes or so it stopped leaking. Start Rescue came out and could not find anything amiss, but only from what he could see. He mentioned that he seemed to remember that because of the changed configuration of the fuel tank and pipes, that disability Berlingos did not like being filled to the top, and this could possibly be why, and advised me to get it checked on a ramp. Has anyone heard anything about problems like this when refilling a disability car ? Would appreciate any advise, thank you.
Threads: 81
Thanks Received: 396 in 339 posts
Thanks Given: 165
20
Most cars have an overflow pipe but that's for when you go over the rim
The fact that it stopped and the rescue guy couldn't find anything is reassuring for short term.
I'd get it checked out
Fill the tank beforehand.
Threads: 4
Thanks Given: 2
You probably overfilled the fuel tank I had a C3 that did that if I overfilled the tank fuel came out of the breather pipe underneath.
Threads: 43
Thanks Received: 411 in 368 posts
Thanks Given: 137
32
I fill my WAV Berlingo until it clicks and it has never leaked out like yours.
Its the first I've heard of this and don't think its anything to do with the way the tank and pipework is fitted. If this is common thing then there would have been a recall . Cant have berlingo leaking fuel over the forecourts because of someone over filling their tank. Possibly a breather pipe loose or popped off
Ass Evdama says get it checkeed out.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 27
Thanks Received: 19 in 18 posts
Thanks Given: 4
12
Better to be safe and get it checked. I'm not in a WAV, but, I go until the pump clicks, and don't top up further like some other people do, even when I did, I've never had an issue with fuel running out somewhere else.
Threads: 19
Thanks Received: 3 in 3 posts
Thanks Given: 3
we've got a wav and fill it until it stops and never had a problem, I've never heard of what you got told
Paul Ryan
Threads: 2
Thanks Given: 2
I have a 2013 WAV, modified with a 30 litre diesel tank. When I fill up past click, and often click several times. More, Almost to the point of over flowing down the paint work. I’ve also noticed a leak underneath the vehicle. It’s happened a few times. But stopping just before total overfill, I don’t get this problem if the vehicle is unladen. With having a dropped floor. A custom fuel tank fitted on the inside, near side rear. Both filler pipe and breather pipe are custom made/fitted and rerouted to tank. Overflow pipe also goes out underneath the vehicle. I’ve noticed it more when the vehicle is under weight of electric wheelchair etc.
Threads: 4
Thanks Received: 13 in 13 posts
4
We have a 2016 Berlingo Multispace XTR BlueHDI 100 WAV.
It’s a GM Coachworks conversion.
We’ve had it since new.
I’ve never noticed any issue with fuel leakage on filling.
I tend to fill until it clicks.
And sometimes beyond that to ‘round it up’.
Never had any issue.
2016 Berlingo Multispace XTR BlueHDI 100 BHP
2010 Berlingo Multispace XTR HDI 90 BHP
