04-08-2024, 09:57 AM
2014 1.6 HDI Partner
A couple of months ago I had a faulty injector replaced. Ever since then I have had the engine light coming on intermittently.
To begin with the fault code was just P0100 Air Flow Measure which would come on occasionally when driving.
Now I'm finding that the engine does not ignite on first attempt in the morning. It turns over but does not start at first. Then after about 30 seconds it will start. This generates a batch of fault codes, all of them intermittent.
P2425:ControloftheBypassoftheEGRexchanger.
Faultcharacterisationpencircuitstatus.:intermittent.
P0030:Oxygensensorheating.
P0100:Airflowmeasure.
Faultcharacterisation:Quantityofairgreaterthantheminimumthresholdstatus.:intermittent.
P050B:Startingmonitoring.
tartingtimetoolongstatus.:intermittent.
P1694:controlledenginestartandstop.
Faultcharacterisation:Faultonthestartermotorcontrollinestatus.:intermittent.
P0245:TBTCommandeduturbocompresseur
Faultcharacterisation:Shortcircuittoearthstatus.:intermittent.
P2426:ControloftheBypassoftheEGRexchanger.
P0003:Controlofthefuelflowregulator.
P0001:Controlofthefuelflowregulator.
P2291:Startingmonitoring.
Faultcharacterisation:Theriseinpressureintheinjectionrailistooslowonstartingstatus.:intermittent.
So far I have cleaned the mass airflow sensor and put in a new battery. Neither the local mechanic or the main dealer have been able to sort this out.
Any suggestions would be most gratefully accepted.
tartingtimetoolongstatus.:intermittent.P1694:controlledenginestartandstop.
