[Steering & Suspension] Shock absorber bolts.
Hi all , does anybody know were I can purchase rear shock absorber fixing bolts. One has knackered when putting new shocks on.  Berlingo multispace diesel 2ltr 54 plate. Thanks
Either a Citroen dealer or if you can find the size and grade then a nut and bolt supplier
Peter
(04-08-2024, 01:49 PM)dixonp Wrote:  Hi all , does anybody know were I can purchase rear shock absorber fixing bolts. One has knackered when putting new shocks on.  Berlingo Multispace diesel 2ltr 54 plate. Thanks
Go to the Catcar info site: https://www.catcar.info/citroen/?lang=en
and put in your VIN
Then drill down through the menus, mechanical, rear shock absorbers and you will get a breakdown with the Citroen part numbers and the bolt size, so then you can search online for them.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Today 11:36 PM
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
