Driver side speaker not working wheN USING
Driver side speaker not working when using a 12volt BT transmitter I have tried different 12volts my next point of interest is the check speaker wiring unless someone can point me in the direction of a potential fix.
Thanks Ben
Does it work normally without the BT
If not working at all then the wiring between the door and the body sometimes get damaged with the door opening and shutting , moving then breaking the wires
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Hi
On normal radio all speakers work fine it’s when I use the transmitter that the problem occurs.
(07-08-2024, 07:22 PM)Benhay Wrote:  Hi
If the speakers all work fine on normal radio, then surely it is your BT transmitter that is at fault? Have you tried the BT transmitter in another vehicle to see if it is definitely operating correctly?
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Diagbox 7.57 download
Yesterday 09:13 PM
Yesterday 05:26 PM
Air filter box removal
Last Post: Harrythephot
07-03-2026 11:03 PM
Berlingo undertray
07-03-2026 08:56 PM
» Replies: 23
06-03-2026 10:10 PM
» Replies: 21
06-03-2026 04:25 PM
06-03-2026 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
