Wiring in the sill
I require a small weld to repair a rust hole in the sill behind the sliding door and wondered it there are any cables inside the sill.
any help is appreciated
(08-08-2024, 01:41 PM)tawalkden Wrote:  I require a small weld to repair a rust hole in the sill behind the sliding door and wondered it there are any cables inside the sill.
Van or Multispace type vehicle? I had some of the panels off the inside of my B9 Multispace to add in some extra power/ charging sockets for when we were using it for camping/touring and all the wiring appeared to be inside of the vehicle. I also did quite a bit of work outside the vehicle over the years [rear and front discs, suspension, wheel bearings, ABS etc] and I'm pretty sure there wasn't any wiring that disappeared into the sills anywhere]
As I stated that was on a Multispace, a van may be different but the vans tend to have less wiring, so I very much doubt anything would need to run in the sills.
_______________
Not a Citroen  Cry
2008 B9 1.6Hdi Multispace XTR
2002 Xsara Picasso 2.0Hdi
1996 ZX 1.9TD Estate
Unlikely to be done at the factory
Eolys replacement tank
Last Post: Harrythephot
Yesterday 12:02 PM
Yesterday 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
