08-08-2024, 04:39 PM
I'm sorry if I don't ask this clearly, I'm not very electrical but here we go:
M59 Modutop 1.6 Petrol
I have a dashcam mirror, than is wired with the power supply neartly tucked so it is powered from the 12v in the drivers side modutop roof storage box. My problem is that this socket seems to be powered all the time, so the dash cam never turns off.... It's killed my battery a few times.
I want to be able to supply power only when the engine is on, and had these thoughts:
1- Tap into the BSI F1 fuse and put a switched fuse piggyback in it's place, so it's needs me to flip a switch to supply power
2- Tap into anther fuse, although this will need me to re-route the wiring to the actual fuse box
3- Use BSM F5 which is supposedly unused, with same cable reroute required.
I like option 1, as for some reason it seems simplest to me, which leads me to the next bit - the switch... I know I can use a cheap rocker that I can simply attach to the fuse panel door/hatch/cover, but instead I have 2 blank dash sockets where aircon switches would go etc if I had it. for a neat solution, I want to put a switch in here and remove the text and replace with "12v", there are a number of rear heated screen switches etc for sale on eBay but they all have pinouts that I fail to understand as it's above my electrical experience.... Could I wire an existing switch to be a simple on/off (that retains the little light when "on", and if so which switch is best to use to do this?
Many thanks for your time reading this
