  • 12 Vote(s) - 3.33 Average
my van won't start
tried to start my van (1.9 d berling 02 reg) turned egnition on waited for 20 seconds(usual procedure) went to turn it over & its clicking very quickly and oil light is flashing very fast, starter motor not turning. Can anyone help? would be much appreciated.
Hi, sounds like a duff battery to me but check your battery connections + earths from the battery to the chassis & engine.
Confusedalut:
  • ron
Battery i would say
Thanks for the reply guys, don't think it's the battery because followed a test from the haynes manual.
1) turn on main beam, watch for 20 sec to see if lights dim (they don't) this is to check battery.
2) leave main beam on and turn ignition key, if lights dim it means power is getting to starter motor and this means there could be a problem with the starter motor (they don't dim)
it also says that if the lights stay bright and no clicking sound from the solenoid this is a fault in the circuit or solenoid (but ours clicks and lights don't dim)
This makes me think there must be a problem with the actual starter motor.
Bumped van started ok ran good but once turn off same problem again, so will take starter motor off tomorrow and get tested.
Will post any updates thanksConfusedalut:
Hi Guys, cleaned earth connections to engine and connections on starter van turned over first time:woop: hope this helps others,
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
