  • 7 Vote(s) - 2.14 Average
clutch cable trouble
hello, i recently had to fit a new clucth cable due to a branch got snaped the old one, i fitted the new but it has snaped in same place, so i dont want to fit another one intill i find the proble3m. does anyone know how and why this is happening? any info would be greatfully recived,
First thing I'd check is the the route the cable follows. Make sure the branch didn't damage a pulley and leave a sharpe edge somewhere that cuts the cable.
ok thanks
(08-05-2012, 08:47 AM)Trebor213 Wrote:  ok thanks
I found that mine had come adrift from the retaining hook on top of the suspension arm (easy to miss, you cant see it from below) and it dropped onto the halfshaft which nearly wore it through. Maybe check that? It depends of course where it snapped. For other posters maybe you could specify?
it snapped at the end where it conects to the clutch, i have fitted a new clutch now thinking that maybe the problem which the cable is now fine an the van drives but now have a small noise when the clutch is not ingaged!!! any help on that?
I had exactly the same problem and 2 clutch cables later ended up having a new clutch kit fitted and the problem was down to an inner?? sleeve that the thrust bearing slide on. Most people dont have this sleee replaced when having a clutch fitted and from what i can gather it seems to be a common problem
wipers
Last Post: mickrochip
Today 11:26 AM
Last Post: xavier988
Today 10:23 AM
Today 10:21 AM
knocking from rear
Today 10:19 AM
footwell fan
Last Post: de62
Yesterday 10:13 PM
rear washer fires front?
Last Post: Brooky325
Yesterday 10:00 PM
Remote key fob window function?
Yesterday 05:58 PM
Halp, me van had died :(
Last Post: ae3
Yesterday 05:43 PM
Drop in fuel economy
Yesterday 09:38 AM
Berlingo in disguise..
Last Post: BlackPartner
11-01-2025 09:47 AM
» Replies: 34
