  • 17 Vote(s) - 3 Average
Fan belt type squealing noise. Or it it?
Hi everyone. My awesome little 2003 1.9D Berlingo has started squealing.
It happens a bit at tickover but mostly at slightly higher revs. Depressing the clutch changes the noise. The noise stops at cruising speeds. It has a hot smell under the bonnet.
I was convinced it was the fan belt (despite fitting a new one only a few months ago)
Except when I pop the bonnet the sound and smell seem to be coming from over the other side of the engine to the fan belt. Although it is hard to tell... I hope someone can advise me on something to check.
I write a blog about all my handmade creations.
Click HERE to check it out.
sounds like clutch release bearing
[-] The following 1 user says Thank You to lorraine for this post:
  • ron
I'll 2nd that. Confusedalut:
  • ron
OK, tell me more if you don't mind?
Will it blow up if we drive it for a few more days before getting booked in to be sorted?
Is it a big job? Could I do it? (I can do servicing and things like fan belts etc. I have done a clutch and a gearbox before but they were a bit of a challenge and I didn't really enjoy.)
If it's squealing then it's running dry which means it's wearing out.
Personally I would get this sorted asap before any other damaged is caused by it's failure.
As for job wise - it's a gearbox remove.
While it's off it might be worth changing the clutch as it might have worn the pressure plate leafs. Confusedillyme:
Confusedalut:
  • ron
Oh no!?! That sounds intense and expensive. How much do you think I should pay to have this done?! Many thanks.
(11-05-2012, 02:02 PM)Handmade Matt Wrote:  Oh no!?! That sounds intense and expensive. How much do you think I should pay to have this done?! Many thanks.
I just looked on the Citroen site and was horrified to see £599 shown for a Berlingo clutch replacement! http://info.citroen.co.uk/finance-and-se...e-repairs/
Thats disgusting, I would look around local to you see what you can find.
I just got quoted the same by my local garage. Rip off, the clutch kit is only £50ish.
I'm going to shop around. Worst case scenario I'll try and do it myself but I'd really rather not.
I've just booked it in at a place for £270 which I think is much more reasonable.
That sounds more reasonable, let us know what they find.
Today 02:32 PM
Berlingo 2026
Last Post: xtimex
Today 05:06 AM
Yesterday 12:15 AM
Yesterday 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
